SoccerNut
Jan 10, 2026Follower
New internet provider opens can of worms
I have a Mesh Wi-fi Router MR60. I just switched to Xfinity with their Gateway at 1000Mbps. Do I use their router and simply use the Mesh satellites as extenders, not using the Mesh's router and Wi-F...
Jan 10, 2026Guru - Experienced User
CrimpOn wrote:If you do not need those applications, there is no need.
Even if you do, there are straightforward approaches to dealing with double NAT.
