Ericwright's avatar
Ericwright
Initiate
Nov 22, 2021
Nighthawk Ax1500 mesh
Just put a new system into my home. I have a NightHawk Mesh 6 wifi AX1500 with 2 satelites. Everything is set up except one satelite is orange and has been since i set it up. why is this one orange? How do i get it hooked up?
System details:
Arris Surboard Cable modem/router-i put this in bridge mode to use.
Netgear nightwawk dual band wifi 6AX1500 Mesh system 1.5 Gbps router+2 satellites
  • plemans's avatar
    Orange or amber? there isn't an orange so I'm thinking its amber.
    The satellite is amber when its not linking to the router.
    If you log into the router, are you able to confirm its connecting to the router?
    What firmware is on the satellite?
    And on the router?
    Have you tried moving it closer to the router and re-syncing it?
