SephGrave's avatar
SephGrave
Nighthawk BE9300 to MR60 AP
Hi friends,
I have my prior mesh system the MR60 with 4 satellites, I have just upgraded my router to the BE9300, this works great but there seems to be several dark spots in my house. I setup my MR60 to AP mode and it shows internet but not give the AP ssid I assigned to it. It is also not syncing with the satellites. Any suggestions?
  • CrimpOn's avatar
    CrimpOn
    I got out an MR60. Connected to my network in 'router' mode and changed the WiFi SSID from the default value to 'MR60Test'.  It appeared on WiFi on channels 1 and 153 as expected.
    Then changed to AP mode, and it continues to appear on channels 1 and 153 as "MR60Test".
    This MR60 is running firmware v1.1.8.142_2.0.69.
    What firmware is on your MR60.  Have you done a Factory Reset on it?
    • schumaku's avatar
      schumaku
      Same here on my MK62 system (MR60 router, 2x MS60 satellites), all operating on MR60 / MS60 Firmware Version 1.1.8.142
      Needless to say pushing the config (like the SSID, ...) from the MR60 (or the MS60) requires a workable backhaul on an established connection for all the MR60 and the MS60.
      plemans wrote:
      Something to keep in mind is the MK60 series was a pretty low performing mesh system because it didn't have a dedicated backhaul and not a very fast front haul. I'm half impressed it even runs with 4 satellites.
      FWIW: These systems were offered as MK62, MK63, and MK64 ..., so out of the box with one and up to three satellites.
      A moderator has moved this thread to the Nighthawk Wi-Fi 6 (AX) Mesh Systems | NETGEAR Communities section as we talk of an MR60 (MK6x Kit) here.
  • plemans's avatar
    You can also try hardwiring in the satellites until they sync and then move them back to where they were.
    Are they hardwired in or in wireless mode?
    • SephGrave's avatar
      SephGrave
      Yeah, I ended up ordering 1000ft of wire and going to hardwire them, I'm confused why the MR60 does not show the custom ssid for it in AP mode.
      • CrimpOn's avatar
        CrimpOn
        If the MR60 is Factory Reset (and defaults to 'router mode') and configured with a unique SSID, does that SSID show up?
        (... after that works, convert to AP mode)
