bigfish
Aug 17, 2020Aspirant
nighthawk mesh app network map
Hi. Am installing a mesh router with two satellites. One is having trouble staying connected, and so while trying this and that, I have gotten it so that both satellites are called Satellite-1. Both of them seem to be working (at least right now), but how can I get them to have different names? A re-setup doesn't seem to do it. Thanks.
Hi bigfish,
To change the names of the Satellites
1) Open Nighthawk app / click network map / click on the satellite you want to name change / click details / edit Satellite name
Kev
- Christian_RNETGEAR Employee Retired
Hi bigfish,
If you recently purchased the device, I would recommend contacting our support team to assist with getting your device installed. You may contact support by using the link below.
https://www.netgear.com/support/default.aspx
Christian
- bigfishAspirant
Thanks. I did eventually get it straightened out.
- knightz01Apprentice
Hi bigfish,
Kev
