CarstensenHouse's avatar
Dec 26, 2022
Nighthawk Mesh AX 3000 no internet connection
Alright so my family bought the Nighthawk Mesh wifi 6 system. The idea was to get rid of the internet provider (century link) rental modem. I had to call the help line because the Nighthawk was not getting connected to the internet. We walked through the set up and it was connected. I asked the agent if I was able to get rid of my modem now since the Nighthawk was a router. And she said yes. So I unplugged the original modem and I am still not getting internet. So my question is.
Is the Nighthawk mesh wifi modem/router able to provide internet without the original modem? If yes then why won't it recieve internet?
  • plemans's avatar
    1. what ax3000 device do you have? That's a speed, not a model number
    2. what modem/gateway from centurylink are you replacing?
    3. did you contact centurylink since they might have their own login info you need to enter into the router?
    4. Is it fibre? DSL? what's your service?
    • CarstensenHouse's avatar
      CarstensenHouse
      Model Number is MK73S
      Century link modem is C3000Z
      I have the admin login info from century link
      its DSL and I have the fastest speed which is 1gig
      • plemans's avatar
        I'm not sure if you're fully aware of what they have setup.
        Reason I say this is DSL doesn't support 1 gig speeds.
        So you must have fibre. does that fibre come into an ONT? or what is it connected to?
        Centurylink is great at requiring their own gateway.
        What I see a lot of people do is use their gateway, disable its wifi, and then put the netgears IP address into the centurylink's DMZ.
