shrimpcaptr45
Jun 12, 2025Aspirant
NIGHTHAWK Mesh Wifi 6 Router MR60 red light
I'm required to have Ethernet connection for work. I use TP AV1000 Powerline Ethernet Adapter PA7017 KIT plugged into work laptop Ethernet cable and the other adapter plugged into Netgear FS105 ProSA...
Jun 12, 2025Guru - Experienced User
make sure the modem is hardwared to the MR60's wan port. Then run from LAN port from the MR60 to the switch and other device. Spectrum only allows 1 public IP address. That should be assigned to the router with the router then assigning private IP address (simplified). IF the work laptop is using that public IP address with the modem being connected to the switch, then the router doesn't get one and only 1 device works.
