rbalcon's avatar
rbalcon
Tutor
Jul 25, 2021
Nighthawk Mesh WiFi 6 system cannot add satellite on wireless network
I bought a NETGEAR - Nighthawk MK63 AX1800 Wi-Fi 6 Mesh Router with Two Satellite Extenders. I am trying to add another satelite but cannot add wireless but only using a cable to the router. If I synch using wiresless it gets stuck on the red light.
  • plemans seems the fix is to use the synch button using the router app "Add Netgear Satelite" feature and then press the synch button on the satelite harware, at the same time, the satelite then connects and the light turns blue, eventutaly. The only issue is if you unplug the satelite you have to setup the synching again, it wont reconnect automatically.
  • plemans's avatar
    Try powering off the other 2 satellites that have already been synced. then when the new one syncs, power the others back on.
    • rbalcon's avatar
      rbalcon
      Tutor
      plemans same result, will only connect when the satelite is wired. I get a red light when I try synching the satelite.
      • rbalcon's avatar
        rbalcon
        Tutor
        plemans got it working now, after reseting it, moving it away form the router and resynching several times, thx
