hewepr1
Jun 08, 2021Aspirant
Nighthawk MK63 - can I connect the satellites via Ethernet (not wireless)?
I am considering purchaisng the Netgear Nighthawk MK63 pack (One router and two satellites) ;-I dont have the budget for Orbi. I've googled for an hour or so and read the installation and user manua...
hewepr1
Thanks PLemans, you truly are a guru. ONe final questions if I may - if I want to connect both the Satellite, can I introduce a gigiabit switch between the router and both the satellites ?
ie :
Router -> gigbabit switch ---> Satellite 1
---> Satellite 2
Will that should work ?
Best Regards
Pete
Christian_R
Jun 11, 2021NETGEAR Employee Retired
Hello hewpr1,
We have receive positive feedback that users we're able to accomplish this setup.
Christian
