iahim
Jul 16, 2025Aspirant
Nighthawk MK73 - AP Mode Satellite won't sync
I have a Nighthawk MK73. So first unit MR70 was configured in AP mode, when i'm trying to add satellite MS70 that is connected via ethernet cable it won't sync always get satellite timeout on the M...
Jul 16, 2025Guru - Experienced User
Are you connecting the MS to the back of the MR or is there a LAN switch in between the MR and MS?
What CAT# LAN cable are you using? CAT6 is recommended.
Does the MS connect to the MR if the MR is in router mode and let the MS connect wirelessly first?
- iahimJul 16, 2025Aspirant
yes cat6 cable
both MR70 and MS70 are connected to Mikoritk with both ports in the same bridge
I don't want to reset again MR70 to router mode to test, it should work in my configuration.
