Boby32x
Nov 02, 2023Aspirant
Nighthawk mr60 mesh system not connecting to security/vice-versa
Hello,
I have a lorex security system that I just installed, as well as this MR60 mesh network router and I cannot get it to connect, no matter what I have tried. I also have a nighthawk ax12 (rax120). The ax12 connects to the security system flawlessly, but not the mr60 for some reason. Assuming maybe a firewall or something?
Last night the ax12 died. Keeps power cycling. I thought maybe I was getting some feedback from other devices that are connected, so I disconnected everything. The cooling fan won't turn on and it just keeps power cycling until it finally just shuts down.
Anyway, is there something I can do to get the security system connected to the mesh router system?
- Turns out that the ethernet cable that came with the MR60 router was bad right out of the box. I replaced it and now everything (including both switches and even the security system) is working.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Try configuring a custom separated SSID network and see if the device will connect to the 2.4Ghz SSID name.
Contact the Mfr of this device there there help and information regarding there product.
- Boby32xAspirantThe modem: spectrum model#ET2251
Nighthawk firmware:v1.1.7.134
Also, the security system is connected via ethernet through a passive switch- FURRYe38Guru - Experienced User
Try the device directly connected to the MR?
What is the brand and model# of this switch?
Be sure to use good quality LAN cables. CAT6 is recommended.
Swap out cabling to see if problem continues.
