ivan42295
Oct 07, 2021Aspirant
Nighthawk MR60 Satellite Ethernet Strength
I have the Nighthawk MR60 which comes with the Router and a Satellite. In my new home, i had to set up the modem and Router in the basement and my satellite upstairs.
I would like to have my work and gaming office upstairs, but for my gaming preferences, I always want to be on a Wired LAN connection directly with the Router.
The Satellite has an ethernet port, but will it be able to support gaming needs vs what directly wired to the main Router?
For reference, my internet provider offers ~200mbps internet.
I just worry that I will experience poor quality if I am wired to the Satellite vs the main Router. Any thoughts or feedback?
thank you community!
Why not put a wired ethernet connection in this area from the MR and install a ethernet Gb LAN switch were, then connect the MS and your gaming system to the LAN switch?
Basements are not recommended placement locations for main wifi routers. Concrete and steel will cause problems with wifi singal coverage.
- ivan42295Aspirant
Thank you for the response.
So I am not sure how that would work as i would still need to run a long ethernet cable to upstairs, no?
So the MR and Modem are positioned in the basement and the MS is upstairs. If i get a switch, wouldn't it need to be connected to the MR (basement)? Then I would still need to run ethernet through the whole house up to the MS and gaming system.
Yes you would need a ethernet wire from the MR to the switch at the remote location.
You can try connecting your gaming devices to the MS while it's wireless connected to the MR and see how it goes.
