Taz145
Jun 14, 2025Follower
Nighthawk MR60 Satellite won't connect
I have an MR60 mesh router and 2 satellites. The entire system used to work fine but recently one satellite is unable to connect to the main router and always displays an amber LED. The router is in...
Jun 15, 2025Guru - Experienced User
If you turn off the working MS, and take the non working MS to same room as the MR, does this MS connect then? Even after try to manually sync it using the sync button in back of the MR and the MS?
Was FW updated on all MS first the the MR lastly?
