JeffB21's avatar
JeffB21
Nighthawk R8500 vs WiFi 6
I was wondering if there is a limit to IoT devices connected to the router.  I have probably 30 right now and with working from home, router seems to struggle.  I don't have any 6g devices so wondering if there is anything I can do to improve the R8500 and if the newer WiFi 6 routers are going to help at all if I don't have any 6G devices?  My thoughts are no that it would not be worh the investment ight now.
  • plemans's avatar
    You should be able to handle 30 devices.
    Its more about bandwidth.
    What speeds do you pay for?
    What speeds do you get wired?
    Are you making sure to have your low bandwidth devices on the 2.4ghz and the higher on the 5ghz?
    Are you using smart connect?
    2.4ghz devices are much slower and sensitive to interference. have you noticed if it happens more on devices on the 2.4ghz?
    Do wired devices have issues?
    Of your 30 devices, how many are streaming video/calls/etc?
    • JeffB21's avatar
      JeffB21
      Our internet is cable modem and 300mbps.  All of the heavy use/streaming devices are on the 5g part of the router.  Daily there are two working from home.  One on 5g and the other directly wired to the modem.  The directly wired is having issues as well. I am using Smart connect on the 5g with both under one SSID.  I have even given devices that are high demand higher priority, however the R8500 has a bug where I can't seem to change them anymore.
      The most streaming/calls will be the two computers.  One wired and one on the 5g.  Most of the issue I have seen is on the 5g side.
      • plemans's avatar
        what actual issue do you get?
        Do speeds slow down? And if so to what?
        Are you getting an error?
        Whats are you actually seeing?
        Thats a bit of key as details can help.
        What speeds do you get over 5ghz?
        What speeds are you getting over wired and 2.4ghz?
        What modem/gateway is it connected to?
