Mtylor's avatar
Mtylor
No powered/unresponsive nighthawk ms60
I've had this system for a year now and the only thing I have had issues with is the satellite. Currently, it has no power going to it even after swapping power cords from the main router and trying a different, working outlet, strip and wall. It was working before so I was wondering if anyone else had this issue as well, and if so, what do you suggest? I currently have it unplugged.
  • plemans's avatar
    Nothing is lighting up on it? not a power led, nothing?
    And you tried a different power supply?
    Sounds like a hardware failure. Are you still in warranty?
    To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. It'll also show you if you're still in warranty or not.
    • Mtylor's avatar
      Mtylor
      No lights at all. It came back on after not being plugged up all night but went dark again. How would I use the warranty because I have till DEC 1 and would like a replacement
