Anhvhoang's avatar
Jan 27, 2024
Please help MS80 connection issue!!!!
Hello everyone,
I've had my MR80/MS80 for 6 months without any problems. However, yesterday, I noticed one of the satellites in my garage continuously switched between orange amber and blue lights. Additionally, the Nighthawk app displayed inconsistent satellite detection, sometimes showing 1 of 2 satellites and other times detecting both. The wired satellite in my bedroom remains stable. All my MR/MS devices are on the latest firmware v1.1.7.14. Any advice on resolving this issue would be appreciated.
  • Interesting that the User Manual (page 15) shows only two colors:
    Usually the first question is, "What Changed?". Could be something as simple as placing some object in the path between router and satellite (garages often are used to "store stuff" and WiFi is sensitive to passing through materials.)  Or, the orientation of one of the devices could have been changed.
    The units have both been rebooted?
    What is the physical distance between router and satellite?
  • CrimpOn's avatar
    CrimpOn
    • Anhvhoang's avatar
      Anhvhoang
      Tutor
      I haven't altered the satellite's location or any settings. My garage is tidy with no storage items. I've positioned the satellite on top of the shelf at a considerable height.
      I haven't attempted a reboot yet. Should I unplug it for a minute?
      The distance between my router in the living room and the garage is approximately 15 feet, with two walls in between. However, it has been working perfectly for the past 6 months, and the issues only started yesterday and today. I continually monitor the Nighthawk app, and it initially detects 1 of 2, then both later. Also it effect my front garage camera weak signal as well.
      The last choice I was thinking is have to run a ethernet wire in to garage for backhawk
      • michaelkenward's avatar
        michaelkenward
        What is your layout?
        Daisy chain?
        MR80 -> MS80 -> MS80
        or star?
        MR80 <- Mr80 -> MS80
        That would be a good start.
        That would be a good idea even if you get the wifi connection to work again.
      Anhvhoang
      Tutor
      So after few hours i decide to reset the Satellite in my garage and also test move it back to where it belong now looking it stable and working but everything inside my garage or outside which is camera stuff is connect to my living room MRouter which it pretty far. I wonder why it not connect to the closest Satellite? is there a way i can a sign it? please help because usually my camera using WIFI signal and it pretty weak since it far away.
      • CrimpOn's avatar
        CrimpOn
        The first step would be to restart those devices, either by using a "Restart" command in the relevant application or by cycling the power to the device.  (Not "Reset". Simply "Restart".)
        Reasoning:
        Devices intended to be mobile are usually programmed to scan the WiFi environment almost constantly, looking for a better connection. In WiFi terms, this is called roaming.  Mesh WiFi systems were developed specifically to use new IEEE standards which facilitate the hand off of devices from one WiFi node to another.  Smartphones, tablets, laptops, etc. almost always have this feature.
        Devices that typically remain in one location are often programmed differently.  When they have no connection, they scan for a WiFi network that they have been connected to before.  When they see one, they attempt to connect.  Once connected, they quit looking. Smart plugs, cameras, garage door openers, thermostats, etc. are often programmed this way.  If they lose WiFi for any reason, they go back into the search mode until a WiFi signal reappears.
        When a device restarts, it begins in that original search mode.  This feature sometimes causes a problem when the entire WiFi system is restarted, such as after a power failure.  If the router begins transmitting WiFi before the satellites, then sometimes devices will 'stick' to the router.
