Cbass1122's avatar
Cbass1122
Rax120 - MK63: want to use the router on MK63 as a satellite or extender
My house is about 4000 sq ft and the fiber modem is outside mounted on the garage with the fiber cables running to the router in the basement, which drives me crazy. Would make this much easier if it were in the middle. I set up my smart home with over 52 devices connected to Wi-Fi at all times. I’m currently using the RAX120 router in the basement with one extender near the steps (25 feet away). I have another router on the main floor connected via fiber Ethernet (Amplifi mesh) and 3 mesh points spread throughout the main and 3rd floors. My question is, would it be best to buy the MK63 mesh (router + 2 satellites) and use them with the RAX120 (assuming I can use the mesh router as a satellite) OR should I just get one or two nighthawk extenders to boost the signal throughout the house? Also have google Wi-Fi I’m not using, but could maybe use those satellites with my router? Thanks
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Cbass1122,
    You can certainly use this setup but keep in mind that you will need to set the MK60 units into access point mode.
    Christian
    • Cbass1122's avatar
      Cbass1122
      Thank you for your reply. That’s kind of what I was planning on doing, but just the router has to be converted to an access point, right?
      Also, I don’t need to directly connect the MK60 router to the RAC120 via Ethernet, right?
      I assume the mesh Set up is a better option than getting an extender or two?
      Thanks again for the help.
      • schumaku's avatar
        schumaku
        To make an AP system out of thr Nightawk Mesh system, yes.
        Of course you do - it's not yet another wireless extender or repeater ...
        Seriously - install a bunch of network cables, ideall in a star configuration from the router to each floor and each place where you consider to connect computers, TVs, or wireless access points. Less cost and effort than buying more and more wireless consumer boxes and kits - where none can make wonders. To many of these in your house already...
        Sorry if this does sound not very popular. And it's not "compatible" to Netgears consumer business marketing too. Then you migh want to look into Netgear's Insight system...
