acayci
Nov 21, 2025Tutor
Connecting a Jetson Orin Nano to a Nighthawk MR60 and Enabling Secure Remote Access
Hello, I’m using a Netgear Nighthawk MR60. I purchased a Jetson Orin Nano, which is essentially a powerful computer with an Ethernet port. Since the MR60 has only one Ethernet port, I don’t have ...
acayci
Nov 28, 2025Tutor
Hi StephenB
I am thinking about the VPN Service configuration.
I believe VPN Service is useful if we are not home and try to connect to our servers. Is that correct? If we are home, can I still have VPN Service enabled without interrupting other connected devices?
Mustafa
Nov 28, 2025Guru - Experienced User
acayci wrote:I believe VPN Service is useful if we are not home and try to connect to our servers. Is that correct?
Yes. It provides remote access to your home network.
acayci wrote:If we are home, can I still have VPN Service enabled without interrupting other connected devices?
You leave the service running on the router all the time.
On the Macbook, you only connect to the VPN when you want remote access.
- acayciNov 28, 2025Tutor
Hi StephenB
I am now following the above Netgear's guide.
I am seeing an error in Tunnelblick.
2025-11-28 14:11:45.165940 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2025-11-28 14:11:45.166061 TLS Error: TLS handshake failed
I am assuming this error is coming from VPN service in Netgear.
