mrwezzle
Sep 15, 2025Aspirant
Does the MR70 need to be wired to the RAX?
I'm trying to do the same with an existing RAX43v2. Will this same process work? If so, does the MR70 need to be wired to the RAX?
- Sep 15, 2025
Yes has to be ethernet connected to the host router.
Disable the RAX radios and configure the MR for AP mode:
Sep 15, 2025Guru - Experienced User
