lKane
Dec 07, 2025Aspirant
MS80 firmware 1.1.8.20 (Dec 1st 2025) Bricked
Yes the firmware update did not complete on the second satellite. I have done every possible thing to connect with the satellite but it just blinks fast then slow in its never-ending cycle. Do...
lKane
Dec 17, 2025Aspirant
Manually update per page 93 of the manual, Wi-Fi connected PC. Manual does not mention ethernet connection
To manually update your satellite’s firmware:
1. Launch a web browser from a computer or mobile device that is connected to your
mesh network.
Dec 17, 2025Guru - Experienced User
Can follow this guide as well for manually updating your system:
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
MS FIRST, then MR lastly.
If your MR is updated prior to the MS, you'll need to downgrade the MR back to what you had on it long enough to get the MS updated FIRST, then update the MR back.
lKane wrote:Manually update per page 93 of the manual, Wi-Fi connected PC. Manual does not mention ethernet connection
mesh network.
- lKaneDec 17, 2025Aspirant
I'm not 100% sure of this next statement, but probably close to 90% sure. After the satellite update failed but before I upgraded the router I tried to connect to the satellite via the router interface but the only option was to select the other satellite. I also attempted to log in to the satellite on the IP address it had before the update but no good. This is only two years old and I don't want to ruin the router.
