MinkaHarry's avatar
MinkaHarry
Rental property - separate system from Home - how do I manage both with the app
I bought two MR60 — Nighthawk Mesh WiFi 6 Router systems. One for my residence and one for our rental house.
Can I switch between the systems on the Nighthawk app?  I want to be able to change the WiFi password on the rental system and keep an eye on it's performance when I'm not at the rental unit.  Can I make this work? or do I need to be in range of the router to access it's info?
  • FURRYe38's avatar
    Yes you can have both connected to the Nighthawk app. You'll need to be connected to either system prior to launching the mobile app.
    • MinkaHarry's avatar
      MinkaHarry
      I have the first system completely set up in the app.  How do I add a second?  I've looked around and it isn't intuitive to me.
      • FURRYe38's avatar
        Set up the 2nd system like you did the first one.
        I presume you'll be setting this up at the other guest location?
