Network911
May 07, 2026Aspirant
RS500 Vlan causes no internet
Alright, I have been messing around with my two routers (RS500 & RAX80) My main router (RS500) has Vlan Tag groups which I set up for my IoT devices. VLAN ID 20, VLAN priority 2, over WiFi 2.4...
- May 07, 2026
Page 94 of the RS500 User Manual describes the use of VLAN which some ISPs require to provide internet.
https://www.downloads.netgear.com/files/GDC/RS500/RS500_UM_EN.pdf
This is NOT a method to create virtual networks to segregate internal traffic, i.e. what we commonly think of as VLANs. Netgear's residential routers do not provide that capability.
By defining a VLAN on the WAN port, you have essentially cut off internet access
May 08, 2026Guru - Experienced User
Also check the RS router. There maybe a separate IoT SSID network feature there. I know on later models there is.
