unimatrixjohnny
Feb 28, 2020Tutor
Split WiFi Networks
Hello, I just purchased the Nighthawk MR60 Mesh WiFi 6 system. I have a couple of indoor cameras that only work on 2.4 GHz, but they are able to connect to a 5 GHz network, so merged networks don...
- Mar 04, 2020
Hello unimatrixjohnny,
Welcome to the community! The MR60 Mesh System currently does not support this feature. However, this would be a great suggestion to be added in our Idea Exchange Board for new ideas to possibly be implemented in the future.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Christian
davel4wa
Mar 15, 2020Tutor
I have expressed the same concern about devices that I have that operate only on 2.4GHz wifi band. As expressed here devices that operate only on 2.4GHz will only connect in that band. The rub is that I have one device that sets up through an Android app and that app requires that the app platform be connected to the 2.4GHz wifi band. Luckily the app has an alternative method to connect and setup the device which works. That being said it is possible, I have now found, using the web page interface to the router, to disable either or both 2.4 and 5GHz radios in the 'Advanced Settings/Wireless settings menu. This should allow you to deal with your 2.4GHz devices setup and you can reenable the 5GHz band once you are done.
MR60 Nighthawk Mesh Wifi Router
schumaku
Mar 17, 2020Guru - Experienced User
davel4wa wrote:I have that operate only on 2.4GHz wifi band. As expressed here devices that operate only on 2.4GHz will only connect in that band. As expressed here devices that operate only on 2.4GHz will only connect in that band.
A device with a 2.4 GHz client only, will always only connect to the 2.4 GHz band for the obvious reason. Nothing is stopping this. The presence of what ever other wireless or wired connection layers is not relevant: These devices simply wont care!
davel4wa wrote:The rub is that I have one device that sets up through an Android app and that app requires that the app platform be connected to the 2.4GHz wifi band.
Talk to the vendor of this Po* - the discovery might initially using some local WiFi connection from the mobile to the device itself, then configure the SSIDs and security, then discover again using some L3 and up protocol. Changing their discovery Apps for not checking a 2.4 GHz connection is established, or to allow to continue regardless would be a snap. Have just set-up an Arlo camera with 2.4 GHz only these days - the App asked to connect to the 2.4 GHz WiFi, said OK, continue, ...knowing the mobile is on the 5 GHz ... the discovery and the set-up went through completely seamless. Gee, on the network there is no difference, regardless if the device is connected on 2.4, 5, 60 GHz, Ethernet, Fast Ethernet, Gigabit Ethernet, 10G Ethernet, 40G Ethernet, ...
Love to hear the idea of using an alternate WiFi router using the same SSID and security on the 2.4 GHz band made the configuration of the same device settings possible. Some IoT makers seem to even check the MAC - so the device won't associate with the Mesh WiFi later - so this does not always work.
