jwknop
Jul 12, 2022Aspirant
Using new firmware on MESH: no smooth upgrade
Hi, I would like to know how the community experience is on upgrading firmware versions on router/satelite configurations like the MK62 (MS60 + 2x MR60)? I've had these Route/Satelites for some time...
Jul 12, 2022Guru - Experienced User
You shouldn't need to.
I rarely factory reset mine.
The only time is if there's an issue after an upgrade and that's pretty rare.
Not sure what's going on exactly with yours that you're needing the factory reset. Might be a good idea to make a backup so reinstalling goes quicker.
jwknop
Thanks for the reply. With reset I meant turning off/on power. Not factory reset. My mistake. But then your reply indicates more or less the same experience as mine that after upgrades there can be issues.
