PaoloPe's avatar
PaoloPe
Guide
Dec 29, 2021
WAN link instability MR60 / MK63 with firmware V1.1.6.122
Hello,
I noticed a concrete instability of the internet connection with the recent firmware version V1.1.6.122 in my Nighthawk MR60 and satellites MS60 (MK63).
The MR60 router is cascaded to a ISP's router but this configuration has worked for me for 12 months without problems.
The only changes were the firmware updates: with the latest the whole system became unstable.
At first I solved it with MR60 reboots when the problem often repeated itself.
The serious symptom is that on reaching the web interface the internet connection was marked "Offline" while my ISP's router works perfectly.
Now I'm back to firmware V1.0.6.116_2.0.54 and I'm not experiencing problems.
The other anomaly of the firmware version V1.1.6.122 that I noticed is on the Netgear Nighthawk android app: I could no longer see the detail of the access point (MR60 or the two MS60s) used by the clients.
Anyone have the same problems?
  • Have you tried correcting the double nat issue?
    A double nat happens when you cascade more than 1 router.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Fixes? There’s 3 options but only use 1.
    1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
    2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
    3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
  • plemans's avatar
    • PaoloPe's avatar
      PaoloPe
      Guide
      Hello,
      I've again upgraded firmware of my MR60 and Satellites of my Mesh wi-fi to version  V1.1.6.122 and implemented the proposed solution n. 2.
      I need to wait at least a week to see if my problem recurs.
