Wyzfar
Apr 13, 2019Aspirant
Access point
Hello I am wondering if it’s possible to use my netduma xr500 as a access point where it’s not connected through WiFi and have it be connected via Ethernet to my modem/router combo and still have the netduma/xr500 capability’s like QoS traffic prioritize etc.
Wyzfar wrote:
Hello I am wondering if it’s possible to use my netduma xr500 as a access point where it’s not connected through WiFi and have it be connected via Ethernet to my modem/router combo and still have the netduma/xr500 capability’s like QoS traffic prioritize etc.A bit confused by this. You want to use it as an access point where its NOT connected through wifi? Or not connected to devices over wifi? But you also want to run your modem/router?
the xr500 has the capability to be used as an AP but if you put it in that mode you lose the routing functionality like QoS.
Why not put your modem/router device into modem only mode or passthrough and just use the xr500?
A little more clarity in what you're trying to accomplish would help with advice. It would also help if we knew what your modem/router is.
- WyzfarAspirantOk so scratch last question. I understand why it would be confusing I put some thought into it, I can put my modem in bridge mode yes I have a new question though would it also be better to use my modems Mac Address I have read about how sometimes bridge mode modem mode etc isn’t actually true modem mode so they use there modems MAC address
- plemansGuru - Experienced UserWell you haven't said what your modern is so rough to tell. Best advice is if it's supplied by your ISP to contact them and have them help you put it in correct mode for using your xr500 as router
