robturpin
Jul 14, 2025Apprentice
All DNS traffic completely suspended for 60 seconds randomly throughout the day
Hi, I am again experiencing an issue that MANY other XR1000 users were experiencing 6-12 months ago (and earlier as well). The symtom is that at several random times throughout the day, ALL netwo...
Jul 15, 2025Guru - Experienced User
Is QoS or Ad Blocker enabled on the XR router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How are the advanced Wifi settings configured?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
robturpin wrote:Hi, I am again experiencing an issue that MANY other XR1000 users were experiencing 6-12 months ago (and earlier as well).
The symtom is that at several random times throughout the day, ALL network traffic would completely stop for about 60 seconds. Absolutely no website can be updated or resolved using any browser for at least 60 seconds. After about 60 seconds. it mysteriously works fine again.
What we all came to deduce was happening through various troubleshooting (in the other thread which unfortunately I can't find now) was that the XR1000 Pro Gaming Routers were set to receive automatic firmware updates by default (meaning right out of the box as well as after a factory reset) and they were timing out whenever they were trying to check for/perform these updates.
I'm not sure if Netgear is aware of this issue (they certainly should be by the many users that are being affected and the numerous posts in various community support forums about it), but they really need to figure this out and start supporting their customers and products!
robturpin
Jul 23, 2025Apprentice
Is QoS or Ad Blocker enabled on the XR router? No, both are disabled.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz. All of my computers are hard-wired using CAT6 or higher, so I don't think the WiFi channels could possibly have anything to do with this issure, but I have tried both auto as well as setting them manually in accordance with my findings on a WiFi analizer.
How are the advanced Wifi settings configured? See above.
What Firmware version is currently loaded? xr1000v2 1.1.0.22_2.1.34
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Xfinity
Model:CGM4981COM
Vendor:Technicolor
Hardware Revision:2.3
Serial Number:368930074436140939
Processor Speed:1503 MHz
DRAM Total Memory:1024 MB
DRAM Used Memory:915 MB
DRAM Available Memory:109 MB
Flash Total Memory:2048 MB
Flash Used Memory:165 MB
Flash Available Memory:1883 MB
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. CAT6
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update? Yes.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Yes, it still occurs.
- FURRYe38Jul 24, 2025Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routershttps://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
Try option #2 first...
