dan801's avatar
dan801
Apprentice
Feb 21, 2021
Anyone know if V2.3.2.114 update is safe on Xr500
I’m currently sitting on firmware **.66 and wonder if V2.3.2.114 is stable and safe to update. I’m not interested in beta testing v3 or anything and googling this firmware brings up stuff about beta testing. I’ve got zero issues with .66 so not sure if I should upgrade to .114
  • The pre-beta .114 just has more security updates in, it is entirely up to you whether you wish to install it or not. I can't see any reason it would cause any issues.
    • dan801's avatar
      dan801
      Apprentice
      Why is Netgear releasing pre-beta firmware versions to general users instead of stable versions?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Sorry I didn't mean it that way. The beta versions are using DumaOS 3.0 whereas the stable versions - the one we're referring to is using DumaOS 2.0. So really what I meant was it's on pre-DumaOS 3.0 firmware.
