xlr8r
Feb 20, 2018Luminary
Assigning a static IP address to home devices
hi folks, this is my first post.
i havent received my XR500 just as yet (as i live in the UK - but is due 1st March via Amazon pre-order).
I have watched a few youtube videos yet Im still not sure exactly where in the OS i enter static IP addresses for quite a few home devices I need to add. From what i seen, the router picks up devices automatically and assigns them Ip addresses via DHCP ? thats not what I want it to do for certain devices.
Can someone please advise where I do this .
i want to assign Static IP's presumably with their MAC addresses ?
I'm formally an R7000 user running DD-WRT firmware, so this is a huge leap to a different OS.
many thanks.
- No benefit I can see, I'd just let DHCP handle the rest of the devices that you don't care about giving a static IP to.
- Netduma-FraserNetDuma Partner
- xlr8rLuminary
aha! perfect thanks.
so, effectively I would need to keep all my home devices DISCONNECTED first, assign the static IP's and then turn everything on to get assigned correctly ?
thanks
- Netduma-FraserNetDuma PartnerYou need to connect them first. Then set the IPs, the devices will reconnect once you apply and then should have the new IP you have set.
