Rx700codmaster's avatar
Nov 30, 2018
Asus rt66 to xr700 upgrade- what to expect
Upgrading from an older asus rt66n router. What to expect and the transition.
Im expecting alot of difference and reading alot about the nighthawk. We plan on streaming movies along with game play, in some instances simoultaneous up and down scenarios.
We also have a surveillance system (cctv) that may be accessed occasionally through port forwarding.
What is to be expected by this upgrade?
  • FURRYe38's avatar
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
    • The modem is supplied by the ISP, no known config is available by end user.
      All utility mods will be accomplished onsite by end user.
      • Netduma_Jack's avatar
        Netduma_Jack
        NetDuma Partner
        I work from Netduma, so I can help answer any questions you have about DumaOS, our router operating system that runs on the Nighthawk XR500 and XR700.
        But first of all, I recommend you go to this webpage to learn more about our features. It will only take 1-2 minutes to read:  https://netduma.com/features/
        We also have a massive roadmap of new features coming out, so it'll only improve your router!
