Sur_justin's avatar
Sur_justin
Best settings for xbox one and xr450
So I recently just bought the nighthawk xr450 and I only have an Xbox one to game. I need help knowing what settings to run!!!!! I have at&t u-verse as my ISP but I always come up with a double bat or I drop internet a lot, also my phone connections are running slow as well. Is there anything that can just drop a link of their settings or help walkthrough the setup with me? Help is very appreciated
  • FURRYe38's avatar
    What FW is currently loaded?
    Wired connection between the router and xbox is preferred.
    Disable "Instant ON" feature on the xbox.
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
    Set WPA2 and AES only for wifi security.
    Disable IPv6, MIMO(if you don't have any MIMO supporting devices) and 160HT on the router.
    Review this as well:
    http://support.netduma.com/support/solutions/articles/16000023979-optimal-settings-guide
