egwok's avatar
egwok
Tutor
May 12, 2021
Bug xr1000 pingheat map goes to default
My xr1000 is brand new and every once in a while the geo filter resets to default after I set it up is this normal ?
  • Sorry to hear that!
    How exactly does it reset? What is it resetting to? How is this indicated to you?
    • egwok's avatar
      egwok
      Tutor
      It use to reset the ping heat map polygon mode I had made but it’s fixed now but now I’m having a issue where I draw the polygon only around servers that are 20-35ish ping and it shows on the duma UI that I’m getting 20-35ish ping lobby but in call of duty Cold War in the ping meter I’m getting 50ish ping .why is this happening ? Plus it lags while playing .sometimes I showed the ping meter in COD Cold War 35ish ping meter but most times is 50ish ping meter and it’s a mess .please help I tried factory reset both router and modem with no luck .
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        The in game ping includes things like processing delay - all games have it. The ping shown on the Geo-Filter is the ping direct to the server which is what you can control. The difference in ping there is about right. If you're not having a good experience then try to force a different server instead and see if it plays better.
