Ricksta72's avatar
Apr 21, 2021
Can XR500 connect to bt homehub 5?
Thinking about picking an XR500 up from Argos, but i need to know if it will connect directly to my bt homehub 5 or will i need a modem? any help is appreciated
  • Thanks for your interest!
    You shouldn't have any issues connecting the XR to the home hub. However, if you do feel free to update us here and we'd be happy to assist!
      • plemans's avatar
        The homehub has its own integrated router functions.
        When you connect the XR500 to it, make sure to put the XR500's IP address into the homehubs DMZ.
