jesse8472's avatar
jesse8472
cannot connect to specific website
cannot connect to specific everything else is fine. i have rebooted, updated firmware, change dns, flush dns, if i plug in to the modem i can get to the website. can anyone help please?
    • jesse8472's avatar
      jesse8472
      yes and now i have done a factory reset now still nothing.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Without changing anything after the reset it is still the same? Weird that it is fine with the modem though. Is it blocked on wifi and ethernet? Does it occur on other devices as well?
