Christiaan11's avatar
Christiaan11
Apprentice
Sep 29, 2022
Cluttered network overview
Hi,
On the DUMA Network overview page of my XR1000 the page gets more cluttered every day. Seems like a lot of "unnamed" devices that change IP after a while keep showing up in the overview making it not readable at all.
So two questions on that:
  1. What is causing all these "unnamed devices" showing up in the overview after they (assumably) connecting through another IP? I'm assuming this because I only have the router for like a month now and had no guest devices connecting to the network at all.
  2. Is there a way to group all the offline devices so the rest is readable again?
Attached a picture of how it shows. Blurred to avoid having all the device names visible. The bottom left are all the disconnected devices.
  • Are you using mac or iOS devices? their private mac/ip address feature can add a lot of "un-named" devices because its creates new ones to randomize it. You can disable that on the mac iOS device
  • plemans's avatar
    • Christiaan11's avatar
      Christiaan11
      Apprentice
      ah, that makes sense indeed. We do have some apple devices indeed. I'm not sure though if I would like to turn this functionality off. Is there a way to hide or automatically remove them from the interface? Are you aware of any options?
      Thanks for the help!
      • plemans's avatar
        Netduma-Liam would have a better idea if you can remove them from the interface. I don't have any of the DumaOS devices.
        In terms of leaving it enabled, you'll continue to get more added if its enabled. And you really don't need it enabled at home. Its more when you're in public where you might have privacy/security concerns.
