Timxes
Jun 23, 2020Follower
Connection issues
I can’t get my 5ghz on my laptop but my laptop has no Ethernet cable ports
Is the laptop 5ghz capable?
What wireless chip is in it?
- Netduma-FraserNetDuma PartnerIf your laptop isn't compatible with 5GHz then you won't be able to benefit from it. If you have a relatively good phone then you should be able to connect to 5GHz to confirm it is working.
