cheese83
Mar 19, 2020Aspirant
Constant DHCP Lease Changes
Lately my router has been constantly changing the DHCP lease per the router logs and it appears to cause me to drop connectivity in game. Literally can't play Fifa online right now because of constant disconnects that match up time wise with the DHCP lease change per the logs. Also causing stuttering on Call of Duty. Is anyone else having this issue recently?
- Netduma-FraserNetDuma PartnerThis is something we're aware of and will be fixing. Assign your device(s) with a static/reserved IP in LAN Settings. Does that prevent the disconnects from happening?
- cheese83Aspirant
My xbox is connected directly to the router and had a static/reserved IP, actually just deleted the connection to see if it would improve things. It did not.
- Netduma-FraserNetDuma PartnerAre any other devices dropping the connection or is it just the device you're playing FIFA on? Wired & wireless devices?
