MdoggTV
Sep 01, 2021Guide
CXR700 duma os 3.0
hey guys I was wondering is there a release yet for the xr700 ? also i am having some dhcp issues were mine is not giving ip's to wifi devices. unless i set them all as static.just wondering is this a known issue
- Netduma-LiamNetDuma Partner
There is a beta version available as you may already know, are you using this currently?
We don't yet have an ETA for the full release I'm afraid, both ourselves and Netgear are working on it though!
- MdoggTVGuide
hey the beta i heard there was one but I am not using it yet, were would i find this at ? also is there many known bugs with it ? just wondering how stable it is
You can find it here:
https://www.dropbox.com/s/1yxwq75k726hkgw/XR700-V1.0.1.34_Dumaos3.0_6.img?dl=0
It's pretty good actually, there have been the odd issue reported but none that are limited to this beta and none than everyone experienced as far as I'm aware.
Be sure to factory reset after installing it, also if you do run into any issues you can always downgrade back to the firmware you're on now.
