Rick6922's avatar
Rick6922
Luminary
Feb 01, 2019
deafult WAN settings
I changed some of the boxs in WAN setup to get it to work on new FW. I just got the 10gtek so I want to switch them back,  does any one know the deafult settings for xr700 ?
  • Set it to dynamically get a WAN IP from the ISP (in >Settings >Internet Setup)
    • Rick6922's avatar
      Rick6922
      Luminary
      I didnt change anything there. it was in WAN setup .
    • Rick6922's avatar
      Rick6922
      Luminary
      if you go to WAN setup theres 5 boxs that can be checked. I changed them to get the router to stop losing internet conection before I bought the 10gtek . I dont rember what they were before. lol   i need some one with the xr700 that hasnt changed them to look at what boxs are checked.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        The only thing that is ticked by default I believe is IGMP proxying
