Cayde-6
Oct 10, 2020Tutor
Destiny 2 on PS4
Okay so what i know is that Bungie recentely has released on console something that let the routers works bad. Also, i know that for resolve this issue you need to update the firmware to 3.0 (beta), i've tried but nothing has changed.
Duma OS 3.0 V2.3.2.104 Beta
Restrict mode: Off
Auto Host Ping: Off
Fast search: Off
Ping assist: 0
Km: 111
Device: PlayStation with Filter on
I've only authorized my IP.
It always worked perfectly, until now.
- You are right in that they have released updates, however it is not as simple as doing a cloud update as normal. It will require actual changes to the Geo-Filter, we are still investigating but this will take some time.
1 Reply
- Netduma-FraserNetDuma PartnerYou are right in that they have released updates, however it is not as simple as doing a cloud update as normal. It will require actual changes to the Geo-Filter, we are still investigating but this will take some time.
