NikciD's avatar
NikciD
Tutor
Dec 15, 2019
Device Manager / Network Monitor Not showing all data
I seem not seeing my devices online when they're being used. Specifically, my XBox doesn't show online, daughter's phone doesn't show online, and my cameras don't show connected. I have the latest firmware. I've done soft and hard resets on my router and it still doesn't show my devices. Not only that but sometimes after recording my 5Ghz doesn't work properly and i have to change the channel and reboot. Is anyone else experiencing this?
  • The devices not appearing online is a known issue and will be fixed. If this is of significant concern you could downgrade to the previous version (if you're willing to miss some security updates) and it will work then. What do you mean by 'recording' the 5GHz?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        How were you doing the reboots? Via the interface or by pulling the power/using power switch? Are you using the Smart Connect WiFi feature?
