Cjw743's avatar
Cjw743
Tutor
Jun 12, 2023
Dos attacks in log
I've been getting a bunch of Dos attacks from the monitoring log, but I look up the IP on who.is and all of them are legitimate companies like
DoD Network Information Center
Apple
Amazon
Palo Alto Networks
 Should I be worried? I heard most of them are fake reports but since these are actual companies does that mean im fine?
  • It's too sensitive so it's a misreading, if you had a real attack your internet connectivity would very likely be impacted
  • and the other ones come from charter communications and I have spectrum internet
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      No you don't need to be worried, they'll just be connections you've made at some point to different services etc
      • Cjw743's avatar
        Cjw743
        Tutor
        Why do they come up as Dos attacks? (like Fraggle attacks) and how do I know when the dos attack is real?
