Kryypt's avatar
Kryypt
Download connection problem
Hello, I have a problem, every time I download I have regular interruptions, the modem of my operator is not interrupting the download. I reset the Netgear + my modem always the same problem,I am on cable internet.
here is a video to understand the problem.
  • plemans's avatar
    1. what router do you have?
    2. what firmware is on it?
    3. what modem/gateway is it connected to?
    4. Are you hardwired or running over wireless?
      • plemans's avatar
        Kryypt wrote:
        XR 500
        Version 2.3.2.134
        internet cable
        Internet cable could be anything. It could be fibre to the home, cable internet, dsl, etc.
        What actual modem/gateway is the router connected to?
  • Thanks for posting.
    Could you please let us know the specific router you're using and which firmware version it's currently running?
    Is it just specifically in Chrome you're having this issue? Does the problem occur in other browsers too?
    • Kryypt's avatar
      Kryypt
      I have this problem also on my console , xr500 firmware 2.3.2.134
  • FURRYe38's avatar
    I recommend changing the DHCP default IP address range to 192.168.1.100 to .200 as well on the router.
