BSlaman's avatar
BSlaman
DumaOS 2.* propper port triggering PS5
HI guys,
I need your help on port triggering. I ran in to a manual that stated the trigger ports for PS5 were 3478-3479 and then the inbound ports are the standard tcp 1935, 3478-3480 and udp 3478-3479. I included some other ports but not sure about them (See screenshot below)
An issue is that with dumaos you can only enter 1 trigger port, so I duplicated each entry so I have a trigger on 3478 and 3479 for eacht inbound port range.
My question is , is this done correctly? I can play games etc, Upnp is turned off. How can I check if this is a working configuration and if its correct? Thanks in advance,
Regards
Bart Slaman
Port Triggering Portmap Table
 #EnableService NameService TypeInbound ConnectionService User
 1 PS5-1935TCP:3478TCP/UDP:1935..1935192.168.4.111
 2 PS5-9308UDP:3478UDP:9308..9308192.168.4.111
 3 PS5-1935-2TCP:3479TCP/UDP:1935..1935192.168.4.111
 4 PS5-80TCP:3478TCP:80..80192.168.4.111
 5 PS5-80-2TCP:3479TCP:80..80192.168.4.111
 6 PS5-443TCP:3478TCP:433..433192.168.4.111
 7 PS5-443-2TCP:3479TCP:443..443192.168.4.111
 8 PS5-3478-3480TCP:3478TCP:3478..3480192.168.4.111
 9 PS5-3478-3480-2TCP:3479TCP:3478..3480192.168.4.111
 10 PS5-3478-3480 UDPUDP:3478UDP:3478..3479192.168.4.111
 11 PS5-3478-3480 UDP 2UDP:3479UDP:3478..3479192.168.4.111
 12 PS5-9308 2UDP:3479UDP:9308..9308192.168.4.111
