Mark9816
Jul 22, 2020Apprentice
eaithernet port speed
I have been getting diffrent color lights on the front of the router for my pc and PS4 Pro. I went in to the router and for some reason my pc is showing 100mg and the PS4 shows 10000mg why??? The router used to show 2 white color lights but now dose not any ideas.
Problem solved I got a USB 3.0 gbt ethernet adaptor and it solved the problem.
Bad connector, bad cable, ...
- Mark9816Apprentice
Ive tried diffrent cables and it did nothing changing ports on the router did nothing. So I guess its the pc then. Thanks
- Netduma-FraserNetDuma PartnerCheck your PC ethernet/wifi adapter, you may be able to change the link speed to 1000mbps - it may be limited by settings or the adapter itself is not capable.
