OlegP
Sep 16, 2018Apprentice
Feature Request: USB Printers
Please concider adding the ability to add a USB printer without the use of the ReadyShare software in your next firmware update.
Other brand routers allow you to simply add a printer to a compu...
Sep 17, 2018Guru - Experienced User
As a suggestion, one can get a print server device and connect up the USB printer to this print server which can be either wireless or ethernet conencted to the network for easy of access to a USB printer.
OlegP
Sep 17, 2018Apprentice
Since I'm using all 4 Ethernet ports already that would mean that I'd have to purchase a switch and a print server, even though with a small tweak to the router's software I could use the USB ports on the router as intended.
- FURRYe38Sep 17, 2018Guru - Experienced User
Hopefully they will. May take longer than expected for that to happen. Suggestions would be much quicker...
Good Luck.
- OlegPSep 17, 2018Apprentice
Do you know if Netgear actually check these forum posts themselves or am I just wasting my time?
I’ve posted twice now about 2 separate issues and haven’t even heard a peep from them.
You can post here about it:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
You'll generally not see anything from NG officially. They supposedly do review that exchange threads for ideas and requests there.
- schumakuSep 17, 2018Guru - Experienced User
The usability of a single direction simple printer access ie. by LPR or Microsoft SAMBA printing is not sufficient for many modern printers drivers requirements.
The software Netgear does provide is creating a virtual USB port, permitting to use any kind of printer, including bi-directional communication, multi-function devices like scanners and much more - just like a USB printer connected direct to the computer. Ways ahead, and much less cumbersome (if it's installable and workable) than any simple remote printer protocol for consumers.
