OlegP
Sep 17, 2018Apprentice
Feature Request: USB Printers
Please concider adding the ability to add a USB printer without the use of the ReadyShare software in your next firmware update.
Other brand routers allow you to simply add a printer to a compu...
Sep 17, 2018Guru - Experienced User
Hopefully they will. May take longer than expected for that to happen. Suggestions would be much quicker...
Good Luck.
OlegP
Do you know if Netgear actually check these forum posts themselves or am I just wasting my time?
I’ve posted twice now about 2 separate issues and haven’t even heard a peep from them.
- FURRYe38Sep 17, 2018Guru - Experienced User
You can post here about it:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
You'll generally not see anything from NG officially. They supposedly do review that exchange threads for ideas and requests there.
