PB975
Jan 18, 2018Follower
Firmware download
I am attempting to download a firmware update. The instructions say to access the url routerlogin.net. The url is asking for a user name and password. neither my netgear username and password nor the router username and password will satisfy the request. How do I log into this url?
The XR500 download are provided on the Netgear support page -> Netgear Support - XR500 Downloads.
The routerlogin.net URL is intended to reach your router when being connected to it's LAN or WLAN. Alternate, use the router LAN IP address, by default it's http://192.168.1.1/ if I'm not worng.
If you are on a different location, and there is a Netgear consumer router in the data path to the Internet - you will reach that device login page.- Netduma-FraserNetDuma PartnerHi PB975, is the issue you're having with the XR500 or a different Nighthawk router? If it is a different Nighthawk router you would receive a much faster and more accurate response at: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Assuming you're on the XR500 (though most of this information will help anyway). I believe the default login information is admin & password. If not it should have that information printed on a sticker on your router (probably the underside). If not of that is working and you still can't connect to it do a factory reset by holding the reset button in at the back for around 20-30s. Then it will take you through the setup and you can set the login details yourself there. Also the information given by schumaku I would recommend you try that first.
