Roadrunner79's avatar
Oct 28, 2018
Firmware to fix download speeds cut in half?
Can I get a firmware to try aside from the AZ 1009 beta???? I have tried everything to figure this out but my download speed is cut in half. Upload is not affected.
  • If we can figure out what's causing it we can fix it. Its either to with PPPoE, VLAN or IPv6. Those are the only scenarios we've seen the issue with.
    • Roadrunner79's avatar
      Roadrunner79
      Guide
      Isp was here on Sunday. Everything on there end is fine. PPOE and VLAN are disabled. Netgear asked me to change  the MTU which did not help at all.
      Roadrunner79
      Guide
      Isp was here on Sunday. Everything on there end is fine. PPOE and VLAN and IPV6  are disabled. Netgear asked me to change  the MTU which did not help at all.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        As this is a new topic can you remind me of the specifics of your case please i.e. expected speeds, what you get, qos settings and what you've tried
