P44EFC's avatar
P44EFC
Apprentice
Jun 01, 2020
full fibre 900 BT
Recently had FTTP installed with BT for the 900 dowload package.   Factory reset the router before using as it had the old connection on and setting back up was easy enough and the wizard got me th...
  • P44EFC's avatar
    P44EFC
    Jun 03, 2020
    Thanks for the response ok i will give that ago when i am home cheers.
