henry85's avatar
henry85
Gateway Wifi Router to monitor wireless temperature sensor and send data to Azure Iot hub
I want to send wireless pressure sensor data to azure IOT hub. For communiction between wireless sensor and Internet, I am looking for gateway Wifi router which can act as access point as well as station and easily create the wifi hotspot with smart phone also.
I want to design a cross platform appliction which will be able to display the values on smartphone by receving the message from gateway router as well as can also use the Azure Database.
    • Hey, Thanks for the reply
      Yes, I am looking for the modem with IEEE 802.15.4 standard built-in with the router
      Does The router You have mentioned use the XBEE devices?
      Or should I have to use connect  Receiver modem with this kind of router to receive the value?
